Here is another small suggestion for improvement: With Sky, the films are unfortunately converted and run a little faster (24Hz to 50/60hz conversion). Unfortunately, this means that the films are no longer correctly recognized by the HEMC and therefore D-Box is hardly possible . It would be great if the algorithm would also recognize these films.
Improvements and suggestions
Also: Is there any possibility to implement a auto standby for the hemc? So i dont have to turn on/off manuel on the device. Or better: Directly From the App !
Mathias, I would like to hear from you regarding this issue?
Mario, what exactly do you mean?
yes, i have This issues , is that what you mean ?
Hello D-Box Team!
I have another suggestion for improvement.
I think it would be cool if you had the option of sound feedback in the d-box seat, for the films you didn’t get a motion code. With the old controller you had the option to select “Audio Mode”, so you could, for example, feel the vibration from the lfe signal in the seat. That would be great if it would also work with the HEMC.
We always appreciate good ideas @CineSnack!
This will be investigate by our engineering team in the future. We’re still figuring out if this will work and/or who it will work.
